NI sbRIO-9651 Serial Write Error
I want to use an sbRIO-9651 to write messages via serial 232 port.
I tested the write function with a very simple vi. Please see the block diagram below:
I always get the error BFFF0015 which says timeout.
I tried both the original clip named kit2 provided by NI and my personal clip, in which I only enabled serial port2 and assigned the lines, input/output direction.
Same phenomenon, both timeout.
I am not sure which step I missed caused my problem.
Please feel free to contact me if more details are needed.
Thank you and regards,
Shu Yan
CLA since 2010 | CTA since 2012 | CLED since 2016
sjtuyan@gmail.com
(2,514 Views)
Solved, need run any FPGA code, to connect the FPGA Chip and the Serial 2 port.
Shu Yan
sjtuyan@gmail.com
(2,489 Views)
