Sb rio connection loss
I am using a single boad card  NI-9642 and I got connections problems.
I can connect to the target but after 2 or 3 minutes, the target disconnects itself, even if I run a simple program. Then I have to reset the target to connect again.
I don't know where the problem came from. I joined the screen shot.
Thanks.
Jean
(4,548 Views)
Hello Jean85,
We would need to know what version of LabVIEW and driver Ni-RIO you are using. Are you using the latest NI-RIO driver? Are you still able to see the card in Max after that the connection is lost? How is the card getting the IP adress? Did you try to use static IP adress?
Thanks for all these informations
Regards
(4,535 Views)
Thank you Mathieu B. for your quick reply.
I am using the latest version of LabVIEW (2011) with NI-RIO august 2011.
When I loose connection, I can't see the card anymore. I have to reboot the card.
The card is getting adress by DHCP.  I already tried to use a static IP adress but I still have the same problerm.
Jean
(4,517 Views)
