03-11-2008 01:16 PM
03-12-2008 10:27 AM
03-12-2008 11:20 AM
Thanks for the raply, Meghan.
I reinstalled FPGA module and now there is C:\NIFPGA82\Xilinx directory. I couldn't see the Compiler Resource item on Configure Server dialog, but the directory does exist. After the reinstallation, I compiled the server and got error message, then I recompiled again, it seemed work this time, no error message. Then call open FPGA reference function in FPGA vi, the vi is broken because it says " the vi is not compiled".
Where should the bitfile be located? I can not find it.
Do you see anything not correct through the procedure I did?
Thank you.
03-13-2008 09:36 AM
Your procedure seems to be correct. The bitfile should be located under X:\NIFPGA85\clntTmp, where X is the drive on which you installed LabVIEW and the FPGA Module.
03-13-2008 10:14 AM
03-13-2008 10:26 AM
03-13-2008 10:36 AM
03-14-2008 04:01 PM
06-16-2010 08:05 PM
I got this error also. This happened after installing LV2009 (on top of 8.5.1) on the PC that I am running the compile server on. I've checked the paths as well as the registry setting for performance counters that was mentioned in another thread.
Any ideas of what can be causing this?
Rgds,
06-17-2010 11:15 AM
I am not using LV2009 but I am guessing the FPGA module wasn't updated properly when you upgrade to LV2009. Try uninstall and reinstall the FPGA module.
And the compiled bit file should be located under \your project folder\FPGA Bitfile\*.lvbit
Good luck!
