I am using a single boad card NI-9642 and I got connections problems.
I can connect to the target but after 2 or 3 minutes, the target disconnects itself, even if I run a simple program. Then I have to reset the target to connect again.
I don't know where the problem came from. I joined the screen shot.
We would need to know what version of LabVIEW and driver Ni-RIO you are using. Are you using the latest NI-RIO driver? Are you still able to see the card in Max after that the connection is lost? How is the card getting the IP adress? Did you try to use static IP adress?
