Programming Omron PID Controller Connected via RS485 to USB
I am trying to create a VI that will control an analogue OMRON PID controller. So far, I have found some information suggesting I will need to program it using Modbus or CompoWay/F. I am not familiar with either of these and I am very new to labview! Any and all help is appreciated!
Further detail:
I have a perfectly functioning PID controller with RS-485 capabilities. I have converted this to USB. Now I need to write a labview VI that will allow me to tell the physical controller what the set point should be, and allow for this signal to change after a certain period of time (so that it now effectively has ramp/soak capabilities)
Thanks!
(2,843 Views)
You might want to start with this whitepaper: Introduction to Modbus using LabVIEW
I didn't see much info on CompoWay/F and LabVIEW from a quick google search so finding specifics on that may be tricky. Hopefully you can get by with just Modbus.
Since you are new to LabVIEW, here are a few more helpful links:
MODBUS Library for LabVIEW (download)
Introduction to LabVIEW (landing page for all the LabVIEW basics [at least look at 1, 2, and 3])
(2,798 Views)
