Programatically setting voltage range for channel on CompactRIO analog input module (NI 9205) with scan interface
Hi all,
is there a way to set the input range of a channel on my NI 9205 with LabView using the scan interface (i.e. not FPGA interface)?
I found https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000YHozCAG&l=en-US but that only seems to be valid for FPGA modules...
Message 1 of 8
(5,836 Views)
right click on module listed in the embedded target in the project, select properties
Message 2 of 8
(5,804 Views)
Thanks, but first word of the header: "Programatically"!
I want to change the voltage range on the fly from a running .vi.
(To be precise the user should be able to set them via a simple config file that's read on startup)
Message 3 of 8
(5,790 Views)
Patrick
I just setup a quick project and looks like property is there. Is this what you looking for?
I'm only setting one channel but you can set all of them.
Miro T
Message 4 of 8
(5,764 Views)
Yes, that's exactly what I was looking for. I just confirmed that it's working and is correctly changing the  voltage range at runtime. Thanks!
Detailed steps to get to what's in  Miro_T's screenshot:
  • In your LabVIEW Real-Time Project expand your chassis
  • Drag and drop the module for which you want to change channel settings into your .vi (this creates a refnum)
  • Rigth click this refnum and choose "Create"
  • You can now select a property / method for which to create a property / invoke node.
  • If you selected a voltage like in the example above you can then right click on the unconnected terminal and choose "Create -> Constant" to get a selection of the valid values.
To be honest I think it's virtually impossible to find this if one doesn't already know where to look (like so often when using LabVIEW). @NI Maybe add yet another KnowledgeBase article with nice step-py-step screenshot instructions? The lack of proper documentation otherwise makes it unnecessarily hard to get such trivial things done...
Message 5 of 8
(5,751 Views)
Well, seems this is not fully solved yet:
Consider I have a refnum to the channel I want to set the voltage range on, e.g "ni.var.io://localhost/Voltage/AI15".
How do I set the voltage range of this specific channel *programmatically*?
In other words: How do I select the required property node programatically?
I can do that now with the steps described above using the UI, but i still have no idea on how I could get this property node dynamically.
Message 6 of 8
(5,719 Views)
Not sure if I understand your question completly... but why cant you just call the property node in your code?
Message 7 of 8
(5,669 Views)
Or are you asking how to create refnums dynamically? If so, see this help document
https://www.ni.com/docs/en-US/bundle/labview/page/reading-and-writing-shared-variables-programmatica...
Message 8 of 8
(5,664 Views)
