取消
顯示結果
搜尋替代
您的意思是:
Power failure sbRIO
I'm working on the sbRIO-9641, and this morning everything was working fine, and then when turning on again the baord there was no LED working and the board won't boot, also there's a sound (tick, tick, tick) coming from the board (I think it's coil).
I'am using a high performance power supply for the board, and everything was OK, I don't know why it failed.
Thank you for your help !
0 積分
1 條訊息(共 3 條)
5,415 檢視
Hello Maaloul
The power LED should be ON. If it is not, you could have a hardware issue and you could contact NI in order to finish troubleshooting and send it for repairing if it is necessary.
Please check manual on page 21 for LED indications. What status do you have?
sbRIO-9641 - LED indications
Regards
Frank R.
2 條訊息(共 3 條)
5,395 檢視
Thank you Frank, all LED are off, no life, and (tick tick tick) sound comes from the inductor next to power supply input.
0 積分
3 條訊息(共 3 條)
5,389 檢視
