NI cRIO-9063 Real-time noise control ability
I am trying to figure out if my cRIO-9063 is capable of implementing active noise control in real time. I found an example code on NI that I am interested in looking into/using for my experiment. However, the 9063 is not one of the devices that can run this code. I am not sure if it would be a good idea to invest in a 9033 for the purpose of running this code if there is a workaround to use my 9063.
tldr: I’m hoping to decide whether I can build my ANC system using the 9063, or whether I need something faster / more specialized like the 9033 or 9053. Any advice or pointers would be super helpful!
(256 Views)
The example is created for cRIO-9033, but you can always migrate it to any cRIO. See Moving Examples to a Different FPGA Target
https://tmesystems.net/
(231 Views)
