FPGA compile error
Thank you
the FixTlist.vi really solved my problem!
Taking this opportunity... how can I see my Xilinx version installed? would be 7.1.03i?!
Message 21 of 23
(951 Views)
That's great! You can see all versions of Xilinx installed on your computer by checking in Windows Explorer. The default path is C:\NIFPGA\... then it will have a folder for each version you have installed.
Danny F
Danny Funk -- Senior Group Manager -- Software R&D -- NI
Message 22 of 23
(948 Views)
For LabVIEW FPGA versions prior to 2010, there should be a separate directory at C:\NIFPGA<version>\Xilinx that contains the tools.  If you look ..\Xilinx\ISE, there will be a readme.txt file that should have the version listed at the top of the file.
Donovan
Message 23 of 23
(946 Views)
