FPGA code for PWM with cRIO 9035
Hello everyone,
I am trying to generate PWM signal for future control applications. For this, I am using the cRIO 9035 and the NI 9474 module and display the signal on a Tektronix TDS 2002C oscilloscope.
I want to generate high-frequency PWM, therefore, I use the LabVIEW FPGA interface. And I create a very simple and basic FPGA VI (PWM0) and call it in the host VI (PWM_FPGA) as shown in this Fig.1 and Fig.2.
Fig.1: Project Explorer and FPGA VI of the PWM.
Fig.2: Host VI.Host VI.png
I can generate the squared signal with both High and Low pulses. But when I increase the frequency I lose the low pulse as shown in the figures below:
F = 5Hz
F = 50Hz
F = 250Hz
F = 1kHz
F = 2kHz
F = 3kHz
F = 4kHz
F = 5kHz
Can anyone explain to me why do I have a problem with the Low pulse. Did I miss something? or do I have to add some sort of configuration?
Any help would be highly appreciated.
(3,283 Views)
Accepted by topic author FaresMZOUGHI
Do you have a pull down resistor? If not, try one. Maybe ~10KOhm.
(3,272 Views)
It worked thank you very much. I connected the PWM signal to a power converter SEMIKRON which has an internal resistor 10kOhm.
Thank you for your quick response.
(3,248 Views)
