12-21-2009 11:33 AM
I have a target program that runs fine on the real time target but crashes when I try and create an executable fron it, error is:
An error occurred while saving the following file:
C:\Program Files\National Instruments\LabVIEW 2009\vi.lib\Motion\FunctionBlocks\straightLineMove\nimc.fb.straightLineMove.startStraightLineMove.axis.modeVelocity.0.vi
Invoke Node in AB_Source_VI.lvclass:Close_Reference.vi->AB_Build.lvclass:Copy_Files.vi->AB_Application.lvclass:Copy_Files.vi->AB_RTEXE.lvclass:Copy_Files.vi->AB_Build.lvclass:Build.vi->AB_Application.lvclass:Build.vi->AB_RTEXE.lvclass:Build.vi->AB_Build.lvclass:Build_from_Wizard.vi->AB_UI_Frmwk_Build.lvclass:Build.vi->AB_UI_FRAMEWORK.vi->AB_CreateNewWizard_Invoke_CORE.vi->RTBUIP_CreateNewWizard_Invoke.vi->RTBUIP_CreateNewWizard_Invoke.vi.ProxyCaller
<APPEND>
Method Name: <b>Save:Target Instrument</b>
Visit the Request Support page at ni.com/ask to learn more about resolving this problem. Use the following information as a reference:
Error 6 occurred at AB_Source_VI.lvclass:Close_Reference.vi -> AB_Build.lvclass:Copy_Files.vi -> AB_Application.lvclass:Copy_Files.vi -> AB_RTEXE.lvclass:Copy_Files.vi -> AB_Build.lvclass:Build.vi -> AB_Application.lvclass:Build.vi -> AB_RTEXE.lvclass:Build.vi -> AB_Build.lvclass:Build_from_Wizard.vi -> AB_UI_Frmwk_Build.lvclass:Build.vi -> AB_UI_FRAMEWORK.vi -> AB_CreateNewWizard_Invoke_CORE.vi -> RTBUIP_CreateNewWizard_Invoke.vi -> RTBUIP_CreateNewWizard_Invoke.vi.ProxyCaller
Possible reason(s):
LabVIEW: Generic file I/O error.
NI-488: I/O operation aborted.
Solved! Go to Solution.
12-22-2009 12:43 PM
Check out these Knowledge Base Articles with some solutions to similar problems
Why Do I Get Error 13 When Building an EXE using Labview Object Oriented Programming (LVOOP)?
Why do I Recieve "Error Code 6 occured at AB_Source_VI" When Building an Executable?
Error 6 with Long File Names on a Real-Time Series PXI Controller
12-22-2009 01:59 PM
