sir
i have a tank, on the base of tank there is a motor, which i am going to control by ni9505, there is one small pump to fill water in tank and a solenoid valve to control the flow of outlet water from tank. tank vibrates due to excitation of motor, so i wants control of this displacement due to vibration like, that every speed of motor this base displacement is minimum. weight of tank in water should change like for every speed of motor base displacement of tank is minimum. for measuring displacement i am going to use laser pickup with ni9234, for solenoid valves and small pumps i am going to use ni9477. i have crio9012 with 9103 chasis.
at here i have one input from laser pickup two outputs to control pump and solenoid valve. control should be real that every speed of motor base excitation is minimum.
mpsingh
