Dear giu7,
I finally installed on my pc. Unfortunately, I faced with previous problem. How can I solve it?
Maziar
Hi!
Try to update your driver, maybe NI-RIO 13.0 is not the correct version.
I'll send a link from which you can download an update version, but check compatibility (readme file) with your operative system and LabVIEW version before download it:
http://www.ni.com/download/ni-rio-15.0/5363/en/
Bye
Is this the same as IAK_SHARED: (Hex 0x8ABC7007) Out of range?
I will try reinstalling the Shared Vaiable Engine.
I am installing the application on the NI 9073 everything was going smoothly until
the deployment of the TC 9213 modules. We get the error message:
IAK_SHARED: (Hex 0x8ABC7007) Out of range.
on both TC modules. We were using the old modules from the customer. Then we tried a new TC module from our stock with the same error.
Then we tested the TC modules in another device (using LV2014) and the TCs are ok. The error occurs only when trying to deploy the original customer f/w (which uses LV8.6)
We are using the same project that was originally deployed to his customer years ago with complete success. The modules seem to be ok, the chassis is new, any idea what is going on?
The Distributed System Manager does not even show there is a TC module.
Thanx
Finally got the project working, but I had to upgrade the F/W part, to LabVIEW 2010.
The s/w can stay at LV8.6 and still talk, fortuantly.
All,
New problem for me and seeing the same issue. Been using this code for years. I get this error message then the code seems to run just fine. Any thoughts why this would now be an issue?
Matt
Initializing...
Calculating dependencies...
Checking items for conflicts. This operation could take a while...
Preparing items for download. This operation could take a while...
Deploying NI-sbRIO-9607-030xxxxx
Deploying SharVar.lvlib\\NI-sbRIO-9607-030xxxxx\SharVar deployment failed (error: -1967357949, OS and Network Services: (Hex 0x8ABC8003) Unable to query Measurement & Automation Explorer for the Network Variable Engine. Make sure the Network Variable Engine (which installs support for network-published shared variables) exists on the RT target and check that the network connection is valid.).
LabVIEW: (Hex 0x80004005) Unspecified error.
NI System Configuration: (Hex 0x80004005) Miscellaneous operation failure.
