Deployment failed (error: -1967357949, IAK_SHARED: (Hex 0x8ABC8003)
Hi to everybody,
I've got the following deployment error:
Which is the procedure to avoid this?
Maurizio.
Message 1 of 17
(9,087 Views)
Hi Maurizio,
Are you using a RIO device and shared variables in your application?
The error is caused by the Network Variable Engine not being installed on the RIO, as detailed in this KnowledgeBase article, which should also guide you through the process of rectifying the issue.
I hope this helps, but please let me know if this doesn't solve the issue.
Chris (CLED, CLA, CTA)
Applications Engineering Specialist
Message 2 of 17
(9,077 Views)
Thanks Chris,
with your suggestion, I fixed the problem.
However I had to go through the "Custom Software Installation" option to install this required addon because, on the standard path for software installation, it said that the option was already installed.
Maurizio.
Message 3 of 17
(9,072 Views)
I myself facing the same problem i again install the Shared Variable version  but agian facing the same problem I am using th TPC 2212 plz guide me
Message 4 of 17
(8,627 Views)
Message 5 of 17
(5,910 Views)
Hi every one, please guide me. how can I fix the above error?
Message 6 of 17
(5,909 Views)
Error indicates that your RT target is missing some software. I would recommend going to NI-MAX and check if 'Network Variable Engine' is installed on your controller.
EDIT:
Based on the backround google search in your screenshot it looks like you "looked" for it 🙂 . If you have NI-RIO installed you already have it, you just need to  install it to controller via NI-MAX.
Here is a general guide how to install software to the controller:
http://www.ni.com/getting-started/set-up-hardware/compactrio/controller-software
Message 7 of 17
(5,874 Views)
Dear Miro,
Many thanks for your reply. unfortunately I could not install it. How can I install it?
Best.
Message 8 of 17
(5,864 Views)
you can't install the software because your cRIO isn't seen in MAX. Make sure that all your physicall connections are right, then follow these steps if you can't see your device in the network:
http://digital.ni.com/public.nsf/allkb/ABE4BC247E8AC9BC8625734E005CAB42?OpenDocument
I hope it can help you.
Bye
Message 9 of 17
(5,842 Views)
Dear giu7,
Many thanks for your reply. I 'll implement it and inform you.
Best,
Maziar
Message 10 of 17
(5,815 Views)
