Can't add FPGA target in project
I've installed labview 2010 with FPGA en Real-Time
In MAX under hardware I see RIO0 under RIO Devices.
I've also installed NI-RIO3.0, this I can see in MAX.
When I try to add my PCI-7831R FPGA target in my project I can't see any FPGA targets.
How can I add my PCI-7831R to my project?
Message 1 of 8
(7,369 Views)
did you install DAQmx drivers / NI driver disc?
NI-RIO won't help as it's the realtime OS running on cRIO devices. Unless you're trying to run NI-RIO as OS on your PC, and I doubt this would work.
MAX should tell you the exact name of the device, not just "RIO0"
Hope this helps.
Regards.
Simo
Message 2 of 8
(7,354 Views)
Accepted by topic author sambuls
LabVIEW FPGA and Real-Time 2010 require NI-RIO 3.5.1.  NI-RIO 3.0 will not have the correct LabVIEW support to create targets in the project even though the FPGA will be detected in MAX.  You can install NI-RIO 3.5.1 from http://joule.ni.com/nidu/cds/view/p/id/2144/lang/en.
Donovan
Message 3 of 8
(7,351 Views)
I downloaded and installed NI-RIO3.5.1 and now I can create an FPGA project.
When I try to compile a program for the FPGA it complains about not having the Labview FPGA compilation tool.
It should be on the FPGA installation disk, but I can't find the compilation tool.
I only can install 'NI LabVIEW 2010 FPGA Module' and 'NI-RIO'
Where can I find the installation source for FPGA compilation tool?
Message 4 of 8
(7,327 Views)
Are you installing from the LabVIEW 2010 Platform DVD or individual installation discs for each module you are installing?
Donovan
Message 5 of 8
(7,324 Views)
I have the individual installation discs for each module. Are you suggesting that I should get the LabVIEW 2010 Platform DVD?
Message 6 of 8
(7,312 Views)
There should be installation discs with the compilation tools, but if you do not have them, you can download the correct tools from https://lumen.ni.com/nicif/us/evaltlktembdes/content.xhtml.  If your board is an NI-781x or 783x, you will need the compilation tools for Virtex-II targets.  For any other targets, you will need the compilation tools for targets other than Virtex-II.
Donovan
Message 7 of 8
(7,272 Views)
Hi, please i have the same probléme with labview 2015
i installed fpga module15  NI-RIO15  but the same problée its ok in MAX but idon't find FPGA target !!??
Message 8 of 8
(5,602 Views)
