11-22-2010 12:06 PM
I've installed labview 2010 with FPGA en Real-Time
In MAX under hardware I see RIO0 under RIO Devices.
I've also installed NI-RIO3.0, this I can see in MAX.
When I try to add my PCI-7831R FPGA target in my project I can't see any FPGA targets.
How can I add my PCI-7831R to my project?
11-23-2010 09:04 AM
did you install DAQmx drivers / NI driver disc?
NI-RIO won't help as it's the realtime OS running on cRIO devices. Unless you're trying to run NI-RIO as OS on your PC, and I doubt this would work.
MAX should tell you the exact name of the device, not just "RIO0"
Hope this helps.
Regards.
Simo
11-23-2010 09:12 AM
LabVIEW FPGA and Real-Time 2010 require NI-RIO 3.5.1. NI-RIO 3.0 will not have the correct LabVIEW support to create targets in the project even though the FPGA will be detected in MAX. You can install NI-RIO 3.5.1 from http://joule.ni.com/nidu/cds/view/p/id/2144/lang/en.
11-24-2010 02:48 PM
I downloaded and installed NI-RIO3.5.1 and now I can create an FPGA project.
When I try to compile a program for the FPGA it complains about not having the Labview FPGA compilation tool.
It should be on the FPGA installation disk, but I can't find the compilation tool.
I only can install 'NI LabVIEW 2010 FPGA Module' and 'NI-RIO'
Where can I find the installation source for FPGA compilation tool?
11-24-2010 02:51 PM
Are you installing from the LabVIEW 2010 Platform DVD or individual installation discs for each module you are installing?
11-24-2010 05:06 PM
I have the individual installation discs for each module. Are you suggesting that I should get the LabVIEW 2010 Platform DVD?
11-29-2010 09:19 AM
There should be installation discs with the compilation tools, but if you do not have them, you can download the correct tools from https://lumen.ni.com/nicif/us/evaltlktembdes/content.xhtml. If your board is an NI-781x or 783x, you will need the compilation tools for Virtex-II targets. For any other targets, you will need the compilation tools for targets other than Virtex-II.
09-24-2015 04:00 PM
Hi, please i have the same probléme with labview 2015
i installed fpga module15 NI-RIO15 but the same problée its ok in MAX but idon't find FPGA target !!??
