CPU-load 100% when reading a FIFO (FPGA target to RT host) cRIO NI-9073
Hi everyone,
I am (again) trying to make an application that reads a specific number of pressure samples at a fixed sample rate to a variable that my real-time application can access when needed.
My CompactRIO is a NI-9073, and I need to read at least 8 channels from a NI-9208 Analog Input module.  I want 512 samples per channel at a sampling rate of somewhere between 500-1000 Hz.
This should be a walk in the park, but the transfer of data between the target and the host is still a complete mystery to me, so I am taking this really slowly.  I am developing a small demo programme to learn, but despite of this I have ran into problems I do not understand.  I was hoping someone with the right skills could help me along…
As it is important that the data are in one continuous order, I decided only to write the samples to the FIFO when it is empty.  The logic I tried to implement is the following:
On the FPGA Target:
- When "Request to Read" is True AND FIFO is empty: Read n samples to the FIFO.
On the RT Host:
- At a given time interval (and the number of elements in the FIFO is zero) send a request to the FPGA to put the samples in the FIFO, then read the n samples into a variable, replacing the existing data in the variable.
As far as I can tell, my programmes seem to be working somehow, but there are two major problems:
1. The load of the CPU displayed in the Distributed System Manager is always bordering on 100% when the VI on the RT-Host is running. Why? This should not be a CPU-demanding application at all (especially not at the rates my demo-programme is running).
2. Some times the variable contains the data and sometimes it is empty.  I do not understand why, as I expected that the data would be replaced by the new data only.
Any thoughts on my mistakes are greatly appreciated!
Martin
(6,677 Views)
Accepted by Martin_T
The following link explains the CPU usage behavior. Basically the timeouts for DMA transfers work a little differently than expected. Always create the block diagram constant of zero as shown in the example or the code will use 100% of the CPU.  Your system will poll the FIFO as fast as possible until the number of elements is reached. http://digital.ni.com/public.nsf/allkb/583DDFF1829F51C1862575AA007AC792
Buddy Haun
Certified Trainer, Former Alliance Member, LabVIEW Champion
(6,665 Views)
Excellent!  That solved my problems.  Thanks a lot!
I improved the VIs based on the ideas I got from the article you linked to, and now my application works like a charm.  I have included pictures of the modified VIs as well as a screenshot of the CPU-usage on the Real-Time Host.
Further suggestions of improvements are of course always welcome!
Martin
(6,652 Views)
