‎06-04-2008 11:33 PM
‎06-06-2008 12:22 PM
Hi Sreenivasulu,
Are you using the FPGA in this card? Or are you using only the instrument’s drivers? The GMSK modulation format is MSK using a Gaussian shaping filter. So you can have a look at the MSK example and notice that one of the options for the shaping filter is Gaussian. You can find the examples at \National Instruments\LabVIEW 8.5\examples\Modulation\RFSG examples. For OOK modulation, one easy option would be to use the example for ASK and select the constellation to be 2. Then you can set the amplitudes to be 0 and a specific value for the symbols. This is basically what Vinay suggested in your other post. I hope this is helpful,
‎06-09-2008 12:11 AM
‎06-09-2008 08:01 AM
Sreenivasulu,
You are correct that MSK, regardless of what pulse shaping filter is used, modulates the message in both frequency and phase, specifically changing the phase in a continuous linear fashion. The frequency deviation is handled automatically for you in our MSK modulation and demodulation VIs and is defined as follows:
Symbol Frequency Deviation = +/- (Symbol Rate / 4)
As you can see, this is identical to CPFSK with an index of modulation h = 0.5. The frequency deviations (represented as symbols) are then converted to phase increments.
You can confirm all of this by opening up the MT Modulate MSK VI and exploring how we set the modulation up. Obviously the the demodulation of MSK, and GMSK, takes all of this in to account.
As for the OOK, you will have to be much more specific about what issue you are currently running into.
Best Regards,
‎06-28-2019 05:21 AM
@Ana P wrote:
Hi Sreenivasulu,
hi Ana P,
according to your opinion,there is no extra filter is required to gmsk transmission and reception,just select Gaussian filter as pulse shaping filter is enough.how can i set the BT value and symbol rate and samples per symbol if i dont know the transmitter parameter.
i have also another question if i want to implement msk i select none for pulse shaping filter options.
thanks in advance.
