02-11-2010 06:19 AM
02-15-2010 10:02 AM
Hello Will,
What is it exactly that you would like to "lock"? Are you looking at synchronisation? What are you trying to achieve?
Is this in relation to AI, AO, or DIO?
Give us a bit more information on what you need to achieve and we will be able to help.
Kind Regards,
Michael S.
NI UK & Ireland
02-15-2010 10:35 AM
03-03-2010 04:02 AM
Hello Will,
I apologise for not getting back to you sooner, is this still an issue?
If I understand what you want to achieve correctly, then you can connect your master reference to one of the PFI lines on the card, and then use the DAQmx Timing function where you specify that PFI line as your Source.
The RTSI bus you mentioned has to do with synchronisation between two NI cards, is this what you have?
I hope this helps a little, let me know your thoughts.
Kind Regards,
Michael S.
NI UK & Ireland
03-03-2010 04:10 AM
