 DanyAllard
			DanyAllard
			06-21-2014 08:44 PM
 Hooovahh
			Hooovahh
			06-23-2014 08:11 AM
Why is the default shortcut L? If you intend on replacing the original replace function it should probably be P.
Get going with G! - LabVIEW Wiki.
17 Part Blog on Automotive CAN bus. - Hooovahh - LabVIEW Overlord
06-24-2014 09:30 PM
 StefanLemmens
			StefanLemmens
			07-11-2014 04:17 AM
07-14-2014 11:34 AM
 StefanLemmens
			StefanLemmens
			07-15-2014 01:24 AM
07-15-2014 08:14 AM
 StefanLemmens
			StefanLemmens
			07-15-2014 08:23 AM
That was already there in the "previous" version but in case of a block diagram function the incoming array is empty. The case structure has "Use Default If Unwired" enabled and nothing is connected on the inside in the false-case. Shouldn't the SelList[] be outputted from this case? As indicated by the green line in this image.
07-15-2014 08:26 AM
 StefanLemmens
			StefanLemmens
			07-15-2014 08:28 AM
