PXI
Sofware install Linux RT PXI
Installing PXI Linux on a PXIe-8880 and I keep getting a dependency issue when I try and install DAQmx.
I have tried installing every package that is in the list, I have also tried just installing the one package (DAQmx).  It looks like you can add additional feeds to a system but I could not find this particular package.
Anybody else seen this?  I am running 19.5 across the board, fresh install.
(2,226 Views)
Somehow the screenshots I put on the original post did not make it to the web.
Before attempting to install software.
Software I am trying to install.
Error that occurs. I have tried to search around to the sync service but I can't find what that might be.
I have also tried installing all the listed packages.  When I do that I get the following errors.
(2,126 Views)
