PXI
SCC-68 with 6341
I can't have access to the configuration of the scc-68 module, i have 2 relay module on module 1 and 2 but can't modify anything Maybe something missing in daqmx. cf picture
(738 Views)
Hello Lucrst,
First of all, I have few questions about your module:
- Has the module worked before, or is this the first time it is being used?
- Were there any changes made prior to this issue (updates, installations, new drivers, etc.) apparition ?
This issue could be caused by various factors, and I don't have enough information to pinpoint the exact source of the problem right now.
One possible cause could be driver issues. The first step could then be to uninstall and properly reinstall the necessary drivers (NI-DAQmx and NI-VISA in this case).
It could also be an electrical connection issue. I suggest checking your setup using the documentation provided here.
If you encounter any problems, I recommend contacting the technical support team for more personalized assistance.
(435 Views)
