PXI
veristand Deployment Error
Hi All,
I am getting the following error please help me solve this.
Project Window.lvlib:Project Window.vi >> Project Window.lvlib:Command Loop.vi >> Project Window.lvlib:Connect to System.vi
<append>=========================
NI VeriStand: VISA Unmap Trigger in NIVeriStand Trigger Routing.lvlib:Unmap TTL0 from all trig bus segments.vi->NIVeriStand Trigger Routing.lvlib:Setup Chassis Routing.vi->NI VeriStand Engine.lvlib:VeriStand Engine State Machine.vi->NI VeriStand Engine.lvlib:VeriStand Engine.vi->NI VeriStand Engine.lvlib:VeriStand Engine Wrapper (RT).vi
Error -1073807360 occurred at Project Window.lvlib:Project Window.vi >> Project Window.lvlib:Command Loop.vi >> Project Window.lvlib:Connect to System.vi
Possible reason(s):
VISA: (Hex 0xBFFF0000) Unknown system error (miscellaneous error).
Thanks in advance,
INFENT
(1,421 Views)
I fixed a very similar deployment error (0xBFFF0010) by re-installing the VISA driver in NI Package manager. It is important to reboot after removing it, install it and reboot again
(635 Views)
