PXI
DAQmx usage for multiple channel read across multiple cards
Hello everyone,
I am trying to use the DAQmx to read all the channels of my PXIe chassis. I have 2 1085 racks with same PXIe4300 AI cards in all slots. I tried to list all the channels in the physical channel input and when I tried to read, it showed me an error about syncing timing across multiple devices.
It doesn't show me this error when I read channels from the same card so I am guessing it is something to do with time syncing across different cards? Is there a way to set up the timing to read all the channels on different slots and different racks using the same DAQmx task?
P.S. I am fairly new to LabVIEW 😄
Message 1 of 8
(2,783 Views)
From Easily Synchronize and Trigger NI-DAQmx with Channel Expansion
A task can include channels from multiple DSA, SC Express, and X Series devices given the following conditions:
  • The devices must be in a single chassis, and the chassis must be identified in NI MAX.
So you would need separate tasks for each chassis. Search for "4300" in Synchronization Explained. Since NI-4300 does not have any PFI ports to route the trigger signal, you would need another module. PXIe-6674T has the best performance.
https://tmesystems.net/
Message 2 of 8
(2,760 Views)
The correct way to synchronize across multiple chassis without timing and synchronization options is to use a 6674T card on each chassis to externally route the triggers.
Santhosh
Soliton Technologies
Message 3 of 8
(2,742 Views)
Thank you for your reply!
Just a follow up, I don't have the 6674-T and I don't think we accounted for it in purchasing. I am okay with segregating my applications and using different tasks for each chassis because the purpose of each chassis is different so that's fine.
In such a case, the master slave synchronization would be enough right?
(I could test this to verify but I don't have access to the rig over the weekend hence just throwing it out there =))
Message 4 of 8
(2,731 Views)
If two chassis are not connected by any means (Timing & Synchronization upgrade, any DAQ device with PFI, or PXIe-6674T), you cannot route any signals between the chassis and do any forms of master-slave synchronization. There are only two separate masters.
Message 5 of 8
(2,719 Views)
Just to clarify, I am using 2 PXIe 1085 chassis with a single 8840 quad core CPU in chassis 1. The two chassis are linked using a PXIe 8384 MXI express X8 module on each chassis.
So does all this hold true for this case as well?
Message 6 of 8
(2,653 Views)
Accepted by topic author Silverfang-
MXI device is not capable of routing trigger signals.
PXIe-1085 has two SMB connectors labeled with IN and OUT at the front that allow you to route the 10MHz between chassis. However, synchronization requires either:
  • sharing of sample clock
  • sharing of reference clock (10MHz clock) and a start trigger.
Although PXIe-4300 has two PFI lines but they are only for digital input and cannot export signals.
PXIe-8840 QC has a SMB Front Panel Trigger that might be able to export the signal. You can try to call DAQmx Export Signal (VI) to export the Start Trigger to /<hostname>/TRIG_SMB of controller in the master chassis (Reference: Use SMB Connector on PXI(e) Controller to Route Trigger Signals), then import the trigger using PFI of any PXIe-4300 in the slave chassis.
Message 7 of 8
(2,630 Views)
yes, it is still valid for your setup. The MXIe card is used for communication and not synchronization.
Santhosh
Message 8 of 8
(2,628 Views)
