PXI
PXIe and Veristand 2016 to PXIe and Veristand 2015 change
Hi.
I was trying to do a project with Veristand 2016 in a computer but it doesn't work so far.
So I will try now in a computer with Veristand 2015.
The PXIe has already all the software for 2016 and 2017, Should I remove all this software and install the one for 2015?
Thanks.
My Channel: https://www.youtube.com/@LV_Lab
(2,770 Views)
Can you explain why it didn’t work the project on Veristand 2016, did you got any kind of error?
You can leave all the software of the other versions there is no problem, but you want for space on your HDD you can delete it.
(2,742 Views)
Because of this this
Are you sure that everything can be installed without removing the other ones?
(2,738 Views)
If you want to install Veristand on your PC, there is no problem you can have many versions as you want. But for the RT target you should format
(2,733 Views)
