PXI
PXIe-4497 Status Code -223022
I have a PXIe-4497 card that out of the blue has failed to initialize whenever I restart my PXI controller.  The status code that I receive is -223022 Internal Software Error occurred in DSA software.  The card appears under "Devices and Interfaces" in MAX as both 3: NI PXIe-4497 "PXISlot3" and 3: PXIe-4497 "PXI20::0::INSTR".  I have tried unsuccessfully to reset the card in MAX and have tried the card in other slots of the chassis as well as in another chassis with no success.  I have other PXIe-4997 cards that are working fine in the same chassis so the issue appears to be isolated to this one card.
I am posting here because I only identified two other prior posts in the community about this issue and both were over a decade old.  Hoping that there may be a way of restoring functionality without an RMA, given that the error code indicates a software issue.  Any suggestions or advice are much appreciated.
Thank you,
Matt
(1,540 Views)
This typically means the firmware on the card is stuck somewhere. The best option is to reach out to NI Support for the next steps to debug.
Santhosh
Soliton Technologies
(1,530 Views)
