PXI
PCIe 8135 problem
There is one software called EPL CFTS  in this web to be used in our lab. Afetr installing it  in the PXIe 8135 embedded system, a text file named PXI connections will appear in the C disk . But I can't modify that file , so I think if you can try installing this software in your PXIe 8135.
Thank you very much.
http://www.masseyeandear.org/research/otolaryngology/investigators/laboratories/eaton-peabody-labora...
(4,320 Views)
What operating system do you install in 8135?
(4,281 Views)
(4,278 Views)
There is only one disk in this system.
1 After copying the PXI connections file to the folders below one by one, only when in windows, users and programme files these 3 folders it can't be modified still.
2 those four text files including the PXI connections can't be modified below in the picture.
3 openning the DotNET, the following message appears
(4,277 Views)
实验室用的是PXIe8135,其系统信息如下
在安装了以下叫做EPL CFTS installer的软件(http://www.masseyeandear.org/research/otolaryngology/investigators/laboratories/eaton-peabody-labora... connections的text文档,在我的系统里无法修改,而且c盘里下图出现的文档都无法被修改,把这个文档分别拷入各文件夹,发现在拷入windows,users,program files这3个文件夹之后依然无法被修改,其他的都行
另外在打开上图中的那个网页时出现了以下信息,他显示的应该是系统信息,现在不明白是不是大家的PXIe8135都会出现这个问题,麻烦用这个控制器的同行安装一下这个软件看看是否可以被修改,谢谢
(4,276 Views)
