PXI
NI 5741 Absolute Accuracy
I've been looking at a lot of PXI and C Series accuracy specs, which usually give either an absolute figure at full range or a percentage gain/offset.
The specs for the 5741 (http://www.ni.com/pdf/manuals/373937b.pdf) are written very differently, and include other components (like DNL) that don't appear in the other specs I have seen.  How can I calculate the absolute accuracy at full scale?
(1,695 Views)
Accepted by johndigsby85
Hey Johndigsby85,
Have you checked out any of the documents on how to calculate absolute accuracy? They should be a great starting point
Calculating Absolute Accuracy or System Accuracy
Calculate Absolute Accuracy of Dynamic Signal Acquisition Devices
Should The Absolute Accuracy Of A Measurement See A Constant or Dynamic Offset?
If the spec has the INL named, this can be treated as a worst case DNL offset, and you don't need to worry about DNL for absolute accuracy calculations. (see Differential Non-Linearity (DNL) )
Hope this helps,
Rebecca
(1,672 Views)
