NI TestStand
simple question to string value test function
Hey guys,
I´m just started by using teststand.
My simple question relates to the "string value test" function. What is the difference between the "Comparison type" CASE SENSITIVE and IGNORE CASE? From my point of view are the names not really self-explanatory.
To avoid simple and stupid questions like that I tried to use the internal help function. Am I right when I say that the help functions are not that good as in labView? I couldn´t find any answer to my question ... hmmm ... how are other people handle this situations? (apart of just trying?)
Thanks for your help 🙂
(3,858 Views)
Accepted by DrSkolsson
Hi
CASE SENSITIVE:   This will fail if you compare    "HELLO" with "Hello"  or  "A" with "a"
IGNORE CASE:       This will pass if you compare "HELLO" with "Hello"  or  "A" with "a"
Hope this explains
Juergen
--Signature--
Sessions NI-Week 2017 2016
Feedback or kudos are welcome
(3,855 Views)
Great, thanks a lot!
(3,852 Views)
