 MarkBlack
			MarkBlack
			02-12-2008 01:15 PM
02-12-2008 04:39 PM
look like I found it...
I think it was the pressure sensor that was leaking the whole time..
THANK YOU EVERYONE FOR ALL YOUR HELP!!!
02-12-2008 05:43 PM
looks like i am wrong...NOOOOOOOOOOOOOOOO....
so yeah..my probllem still exist..i dont know what is going on..
my version of test stand is labview 7.0
i have MAX 3.1
i have IDaQmx 7.4
i was thinking to upgrade it to 8.6 but i think it will not work with my system because of the serial port..
i am using a ubs to serial adapter as well.
 MarkBlack
			MarkBlack
			02-13-2008 11:32 AM
02-13-2008 11:45 AM
02-13-2008 12:33 PM
 MarkBlack
			MarkBlack
			02-13-2008 01:02 PM
02-13-2008 01:21 PM
02-13-2008 01:21 PM
02-13-2008 04:20 PM
FINALLLY!!!!!!!!!!!! i found the problem..
in all my systems, the only system that don't have the pxi-4060 cards is the system with the memory leak.
my co-worker said that because we are not using a thermistor in this system, so therefore we don't have to have the PXI-4060 in the chassis pxi-1042. I guess what was causing the leak was data being poured into the array where the data of the thermistor is holding and it takes up memory. I replaced the chassis with the pxi-4060 in with the other chassis and there are no leak in memory..i guess that did the job..
THANK YOU EVERYONE FOR YOUR HELP!!! especially BlacQmx. i think without advices from the experts, i would never discover it.
THANK YOU ONCE AGAIN!!!!
