NI TestStand
how to get code deployment date to the RT?
I am using LabVIEW 8.5 and MAX 4.4.1f0 and cFP-2110. I want to retrieve the date of the deployment. Is there any way to retrieve the code deployment date to the RT?
 Mamun
(2,966 Views)
i think you should have posted this on the LabVIEW FPGA board
regards
Ray Farmer
Ray Farmer
(2,955 Views)
Accepted by Mamun
Hi Mamun,
You should be able to FTP into your cFP-2110 from a Windows Explorer window and check the "Modified" date of the startup.rtexe in the /ni-rt/startup folder.
Aaron P
Applications Engineer
http://www.ni.com/support
(2,925 Views)
