NI TestStand
disable array plot in TestStand output file
How do I disable TestStand from plotting a logged array in the output file. I logged a Labview array read into TestStand, TestStand plots the array whenever the array is numerical. This only clutters my report, no need to plot this array.
(2,931 Views)
Have you unchecked the "Log" column for the output parameters in the module tab of the step settings?
(2,930 Views)
I want to log the Labview numerical array and not plot the array in the report file. In other words, display the array values in the report file, not a plot of the numbers.
(2,912 Views)
Hey,
This is actually a setting for your overall generated report. In the contents tab of the report option, under the "Include in Results" section, change the option for arrays to be included as a table rather than a graph.
Let me know if you have any more questions,
Roxy
(2,910 Views)
Thanks.
I noticed the navigation for this report option contents tab is kind of hidden. Configure \ Result Processing, click the Options icon.
My Administrator disable me from changing, is there an expression to change the IncludeStepResult... to change this?
(2,893 Views)
