‎04-10-2019 10:01 AM
How do I disable TestStand from plotting a logged array in the output file. I logged a Labview array read into TestStand, TestStand plots the array whenever the array is numerical. This only clutters my report, no need to plot this array.
‎04-10-2019 10:04 AM - edited ‎04-10-2019 10:05 AM
Have you unchecked the "Log" column for the output parameters in the module tab of the step settings?
‎04-11-2019 07:35 AM
I want to log the Labview numerical array and not plot the array in the report file. In other words, display the array values in the report file, not a plot of the numbers.
‎04-11-2019
09:09 AM
- last edited on
‎10-20-2024
05:43 PM
by
Content Cleaner
Hey,
This is actually a setting for your overall generated report. In the contents tab of the report option, under the "Include in Results" section, change the option for arrays to be included as a table rather than a graph.
Let me know if you have any more questions,
Roxy
‎04-12-2019 06:29 PM
Thanks.
I noticed the navigation for this report option contents tab is kind of hidden. Configure \ Result Processing, click the Options icon.
My Administrator disable me from changing, is there an expression to change the IncludeStepResult... to change this?
