NI TestStand
Writing arrays of clusters into TestStand
In TestStand, I made a custom data type, a container of two strings, then added an initially empty Array of this container as local variables to a sequence (myList: Array[0..empty] of myEntryType). I need to populate this array in LabView.
The "Set Property Value (string)" VI doesn't work, as the array is empty and attempting to give array indices results in a TS Exception, and I haven't been able to use AsPropertyObject and SetValVariant either (SetValVariant raises an Exception: "Specified value does not have the expected type.")
Any Ideas?
(3,737 Views)
Tony,
You will need to resize your empty array and then write to it. To resize your array you must first get a reference to it by using the VI "TestStand - Get Property Value (Object).vi". You can then use an invoke node to call GetNumElements and SetNumElement to get and set the size of the array. You could also invoke SetDimensions. Now, using the appropriate lookup string, you can set the value of the array element(s).
Attached is an example that demonstrates this. I would recommend cleaning it up by grouping things in subVIs. Let me know if you have questions.
(3,737 Views)
