Write in SQL Database Issue
I'm trying to use a database and I'm reading from it without any problems, but when I try to write, I get the following error (please see picture):
Can you please help me?
Thanks in advance
(730 Views)
The error in English is "The operation is not permitted for a closed object" and this suggests that either the data operation does not match the SQL object you opened. The Put and Set New Record data operation is for a Recordset object. You should use the Execute operation, which is for INSERT command, which will specify the parameters to use when inserting the new record.
Scott Richardson
https://testeract.com
(700 Views)
Hello Scott,
thanks so much for your time and answer. I was trying to use the "Execute Procedure" but I´m getting also error.
Please see attached pictures.
Thanks so much again
(683 Views)
As for the first two error messages, do Time  an ID  really exist in this context?
The third one is obvious, since you are trying to write a number to a field which should be a string value
(679 Views)
Hello Oli,
my SQL statement is:
"INSERT INTO HV_TestStatus VALUES ('" + Parameters.Date + "','" + Parameters.ID + "','" + Str(Parameters.Counter) + "')"
and they exist in the same order in my database. If I do it with "Put New Record" it gives me an error but it does save the data correctly.
(674 Views)
