NI TestStand
Watch View in TestStand OI
In my custom LabVIEW-TS OI I would like to add the Variable Watch View similar to what we see in TestStand OI. Is it posible?
If Watch View is not possible what would be the best way to let the user view all the Local variable valuesof the Main sequence at Runtime? Thanks.
(3,954 Views)
In terms of a pre-made control, no, there is not a way to get the Watch View to display in your LabVIEW OI.  However, you can use custom UI Messages to update indicators in you LabVIEW OI, when variables in TestStand change.  A good article/tutorial on how to do this can be found here:
http://zone.ni.com/devzone/cda/tut/p/id/4532
Shelby S
Applications Engineer
(3,927 Views)
