NI TestStand
Changing Report FileName on the after UUT Testing
I want change the name of my Test reports file after UUT testing - based on data extracted from the UUT.
Is it safe to simply change the "RunState.Root.Parameters.TestSocket.ReportFilePath" variable in the Post UUT loop and delete the old file?
I am using a parallel process model.
Thanks & Regards,
Shane.
(2,926 Views)
I am going to keep this on one thread to make it easier to lookup in the future.
http://forums.ni.com/t5/NI-TestStand/Changing-Report-FileName-on-the-after-UUT-Testing/m-p/1436150/h...
Best Regards,
Adam G
(2,911 Views)
