NI TestStand
Using Test Stand API in VBA
I want to write a macro using VBA and TestStand API. I'm trying to get an Engine object. I created an TestStand Engine Class ActiveX control. In it's Sub procedure I have a following code:
Dim eng As Engine
eng.NewSequenceFile
This Sub I'm calling from another Sub and I'm getting an error: Object variable or With block variable not set. Do you know how it should be done?
(1,542 Views)
Try using
Dim eng As New Engine
That should work.
Armen
(1,447 Views)
