NI TestStand
Mathscript in VIs to use in Teststand
I'm using Teststand to create a small test sequence where I need to use a VI with a MathScript Node executed by MathScript RT Module. In MathScript Node I have a filter_zerophase and when I add this VI to an action in TestStand the message "Unable to load..." appears on Module tab. If I remove the filter_zerophase of the MathScript node everything works fine. Any one knows why this happens?
In this link (http://zone.ni.com/reference/en-XX/help/373123C-01/lvtextmath/msfunc_filter_zerophase/) we can see that filter_zerophase is supported in the LabVIEW Run-Time Engine.
Ruben
(1,560 Views)
Accepted by topic author rgpbrito
Hi Ruben,
The reason why you are unable to load a VI with a MathScript node is because MathScript requires specific VIs from the LabVIEW library. You need to create a source distribution for your VI that would include the required libraries and then load the your VI from the source distribution.
You'll find here an article in the NI Knowledge base that details the procedure: https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z0000019Nn8SAE
Hope this helps!
Karim.
(1,531 Views)
Hi Karim
Thank you ... I had already tried this procedure, but unfortunately it hadn't worked.
Once you've suggested this approach, I've tried it again and it didn't work again. However, I realized that I was choosing the relative path instead of choosing the absolute path.
Ruben
(1,528 Views)
