Showing results forĀ
Search instead forĀ
Did you mean:Ā
Using LabVIEW algorithms on CTD test
On my recent run of CTD, I got 18% because my LabVIEW algorithm didn't transfer to their tester.  On my side, I zipped and unzipped the code 4 times to make sure it worked...
My question is, has anyone successfully used LabVIEW code on the CTD test?  If so, how did you do it?
CLA
Message 1 of 9
(1,526 Views)
By LV algo, do you mean the drivers provided by NI to build the sequence?
Santhosh
Soliton Technologies
Only two ways to appreciate someone who spent their free time to reply/answer your question - give them Kudos or mark their reply as the answer/solution
Message 2 of 9
(1,510 Views)
I mean an algorithm performed on the data retrieved from the simulated instruments.
CLA
Message 3 of 9
(1,508 Views)
Accepted by topic author UnholyPenguin
You will be implementing all the logic in the Sequence itself. It should not depend on any user-developed external code.
Santhosh
Message 4 of 9
(1,506 Views)
Well, I guess I have A LOT to learn than šŸ˜…
CLA
Message 5 of 9
(1,504 Views)
Santo, do you have any advice for learning more TestStand syntax? Small practice tests like the CLD 1-18 practice cases?
I took the live training course and did the practice exam 5 times.  However, I found they did very little to teach me the complex TestStand algorithms that were needed for the real test.  I'm finding all TestStand resources to be deprecated/link down/host website down when researching old CTD practice questions.
CLA
Message 6 of 9
(1,459 Views)
CTD is straightforward compared to the requirements of CLD. On the other hand, on-the-job experience with TestStand will help you pass the exam rather than just the training or practice tests.
Santhosh
Message 7 of 9
(1,456 Views)
I think on the job I would use LabVIEW or Python to write algorithms. I thought TestStand was supposed to be a sequencer to plug-in algorithms from existing programming languages! šŸ˜…  I guess I'll go through forums and try to answer some community questions for practice
CLA
Message 8 of 9
(1,454 Views)
You're correct. In the scope of CTD, since the choice of programming language will vary, code module is provided out of box and the developer is expected to focus on using the existing code module in the sequence and thereby they can evaluate only the TestStand knowledge and not how you implement logic in the code module.
Santhosh
Message 9 of 9
(1,446 Views)
