 SimpleJack
			SimpleJack
			01-28-2010 10:30 AM
Here is a question(s) I hope someone can answer.....
Once I have a deployed Teststand System, how do I easily add operators to the test setup if the development system isn't installed. Can it be done locally?
Also, a few COM port settings in my system globals can vary depending on the PC it is installed on. To change these, I think all I need to do is create a sequence file to prompt the user for the new com port. But how can I do that without loading the station model first? I just want to run the sequence independantly.
Ryan
01-29-2010 10:08 AM
Ryan,
One option would be to deploy the fully featured user interface. You can get more information on deployments through chapter 14 of the teststand reference manual. It will allow you to edit variables, add operators, etc. You can also run a sequence without running the process model by going to execute » run main sequence. This will bypass the model entry points. Another way but more difficult would be to directly call into TestStand's active X server through labview/cvi/measurement studio and add users and manipulate variables through the TestStand API.
01-29-2010 10:20 AM
Thanks Richard. That answers my question about the user interface.
However, referring to bypassing the model. Once I have just the deployment license running, I don't believe I can just run the mainsequence so I would need to code it into the sequence somehow.
02-01-2010 01:12 PM - edited 02-01-2010 01:13 PM
You can use the main sequence entry point when you deploy with the fully featured user interface. C:\Program Files\National Instruments\TestStand 4.2\UserInterfaces\Full-Featured
If you like you can also call entry points using the TestStand API and directly interfacing with the Active X server. http://digital.ni.com/public.nsf/allkb/55DB46310B17F6DA86256CDA007720A9
 Dennis_Knutson
			Dennis_Knutson
			02-01-2010 01:50 PM
