NI TestStand
Unload Single Sequence during debug
Is it possible to unload a single sequence from the standard full featured UI during debug?
I have a large test program that contains multiple sequence files.  The initialization sequence contains a few LabVIEW FGVs that store reference information to test equipment.  During debug it would be nice to edit a single VI without having to stop and restart the entire sequence execution.  If I use the typical "File/Unload All Modules..." from the UI during a break I can edit the VI but I lose all the test equipment references in memory.  Is it possible to somehow add a function to only unload the current sequence file on the fly?  I know I can do this by adding the expression "RunState.Sequence.UnloadModules()" in a given sequence step but I only want it there during debug.  I tried adding it to a separate sequence file that gets called by a new Tools menu entry but I can't figure out how to get a reference to the calling sequence file to unload just that one sequence module.  I don't really want to have to create a new UI just to add this function.  Any other ideas?
Thanks in advance,
Jason
(2,961 Views)
Accepted by jason1
RunState.InitialSelection.SelectedFile.UnloadModules()
The InitialSelection object is pretty awesome if you ask me.
jigg
CTA, CLA
testeract.com
~Will work for kudos and/or BBQ~
(2,932 Views)
Thanks jigg!  That works perfect. I wasn't aware of this object before.
(2,907 Views)
