NI TestStand
Timeout on while loop
I need to insert a timeout on a while loop to exit this loop in the case of the device isn't able to answer.
How can I do ?
Best regards
(7,912 Views)
Accepted by ThGO
Create a Local Variable:
Locals.StartTime
In an expression step before you start the while loop set Locals.StartTime = Seconds()
As part of the condition for the While Loop use: (Seconds() - Locals.StartTime) < X
where X is your timeout in seconds.
Hope this helps,
jigg
CTA, CLA
testeract.com
~Will work for kudos and/or BBQ~
(7,903 Views)
Thank you it works very well.
(7,889 Views)
