NI TestStand
Modify local variables with C# dll
 void AppMgr_UserMessage(UIMessage uiMsg)
  try
    switch ((int)uiMsg.Event)
      case 10200: //update the UI to reflect the current progress
        progressBar.Value = (int)uiMsg.NumericData;
        label.Text = uiMsg.StringData;
        break;
      case 10201: //Close the form, cleaning up the AppMgr Reference
        AppMgr = null;         this.Close();
        break;
      case 10202: // Send text to the calling Test Stand App
        label.Text = "10202";
        uiMsg.AsPropertyObject().SetValString("Locals.opText", 0, "Something");
        break;
This is some code from your Floating .Net panel example
In the last case above I am trying to modify one of Test Stand's local variables. I think it is probably not sensible to cast uiMsg as a PropertyObject the way I have here.
I think it is more likely that I will have to pass the variable I want to modify from Test Stand to the DLL.
Not sure how to do this, any ideas ?
(6,693 Views)
Accepted by topic author krugman2
Hi Krugman2,
To do this you need the coresponding SequenceContext!
Try uiMsg.Thread.GetSequenceContext(0,frameId).AsPropertyObject()
Maybe this thread could be interresting:
http://forums.ni.com/ni/board/message?board.id=330&thread.id=17870&view=by_date_ascending&page=1
Greetings
Juergen
--Signature--
Sessions NI-Week 2017 2016
Feedback or kudos are welcome
(6,683 Views)
That worked well, thanks
(6,663 Views)
Bonjour, Est ce que il y a une possibilité de recuperer la version de test dans testStand et l'afficher dans une textbox en c# sachant que j'utilise le c#
(5,488 Views)
