Teststand Run-time Engine Version For Labview
Hi Sir,
Is there any method to change the RTE of teststand, to match the labview VIs ?
Thanks.
Learning from other people
(1,408 Views)
Accepted by topic author Brzhou
You need to install and run a different version of TestStand to change the RTE version. We usually change the version of the LabVIEW adapter instead.
How to Change the LabVIEW Version TestStand Uses
https://tmesystems.net/
(1,368 Views)
Oh, thanks.
Sounds like I do not need to install the teststand again, i just need to do the configuration in the existing one.
(1,359 Views)
