NI TestStand
TestStrand propertyLoader from XML based file
I have XML file, how to convert it in a smart way to XLS or comma separated file that after it i can load it automatically via PropertyLoader.
I use TestStand 2021, any one has already ready to use parser from XML to XLS or comma separated file?
Any one knows C#/Python based library that can help convert XMl file to XLS or comma separated file?
Example of XML file is:
<?xml version="1.0" encoding="UTF-8"?>
<projects>
<COMMON>
  <StationGlobals>
              <Station.DBName>testDB</Station.DBName>
  </StationGlobals>
  <FileGlobals>
  </FileGlobals>
</COMMON>
<ProjectX>
  <StationGlobals>
   <psequence delay=5>GPIB5::INSTR0::KEYSIGHT,GPIB6::INSTR0::KEYSIGHT,GPIB5::INSTR0::KEITLEY</psequence>
   <dsequence>GPIB3::INSTR0::34401,GPIB21::INSTR1::34401</dsequence>
   <Station.S enabled=TRUE ></Station.S>
  </StationGlobals>
  <FileGlobals>
   <valid1>9</Ampl_valid1>
   <valid2>9</Ampl_valid1>
   <valid3>9</Ampl_valid1>
  </FileGlobals>
  <Locals>
   <corners>
               <H VOLT=2></H>
              <C VOLT=1></C>
   </corners>
  </Locals>
  </ProjectX>
Thank you!
Thank you & Best Regards
*I use LabVIEW 2018 & TestStand 2021 versions
(1,324 Views)
Hello Yuri,
For performing XML to xls conversation by Python, you can refer to this link: Convert XML Spreadsheet to Excel file in Python | EasyXLS Guide
Best regards.
(1,281 Views)
