I need to display similar pass/fail/error and terminate banners that comes with sequential model when I use parallel model. Test sequence is run in parallel or sequential model based on UUT being tested.
As I have overridden PreUUT callback in parallel model, I am unable to use default modelsupport2.dll implementation of these banners when I copy it from sequential model to parallel model.
Is there a way to use these? or should new banners created in LabVIEW to call in PostUUT callback? Just need banners to look identical with test sequence is run with either model.
Thanks!!
CLD
