‎04-10-2014 10:54 AM
When TestStand is launched, getting a popup window - 'Value must be at least 0'. What does that mean?
Will it make any effect on test sequence execution?
‎04-10-2014 12:46 PM - edited ‎04-10-2014 12:49 PM
This is a rather unusual error--I have not heard of it before, so we'll need to do a bit of further debugging to determine the cause. Here are a few questions that might help us narrow this down:
Could you attach a screenshot of the error message?
Does it occur before or after you see the login dialog in TestStand?
Has this always occurred, or did it recently start occurring?
Which version of TestStand are you using, and on which operating system?
Thanks!
‎04-11-2014 02:42 AM - edited ‎04-11-2014 02:42 AM
To add:
I assume that you re-load the sequence files which were not closed last time you closed TS. Is it possible that one of that has a "SequenceFileLoad" callback implemented?
Does this error occur with any user interface or in the NI Sequence Editor only? If it only occurs in one UI: What makes this UI special? Is it custom made?
Norbert
‎09-09-2020 03:56 PM - edited ‎09-09-2020 03:57 PM
Any clues on how to solve this situation?
I ended up having this same problem today.
Every time I open teststand application I get this popup with "Value must be at least 0"
If I click OK, it will go away, but I can't open any sequence, existing or new one.
Also if I try to open a .seq through workspace, I get another error message. (see below)
EDIT: found this on the internet, but did not solve either: https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000wwyACAQ
‎09-17-2020 06:39 AM - edited ‎09-17-2020 07:09 AM
Up, I have exactly the same issue with NI TestStand Engine Version 2019 (19.0.0.170) 32-bit....
Help from an NI Employee please ?
EDIT : Can you please delete this knowledge base ? It simply doesn't work...
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000wwyACAQ&l=fr-FR
‎09-17-2020 03:54 PM
Another step to try is to rename your users.ini file to something else and then Reopen TestStand so it creates a new users.ini in case there is something wrong with the ini file when you open TestStand and it starts the login routine.
‎09-18-2020 12:48 AM - edited ‎09-18-2020 01:15 AM
Hi Dane !
I just tried to rename Users.ini.
TS indeed creates a new Users.ini file, but the issue is still here unfortunately...
That's weird. Should I try to delete all the Cfg folder ?
EDIT : I tried to rename the 2 only files which were modified the day the bug appeared ("StationGlobals.ini" & "TeststandPersistedOptions.opt", last modification 9/17/2020). I tried as well to copy and paste those 2 files from another PC with a correct TS.
Issue is still here...
‎09-18-2020 10:43 AM
Hi Bilsix,
Thank you for bringing this to our attention. I have passed your feedback to our web content team to review.
‎09-18-2020 02:58 PM
Could you potentially try to capture a crash dump of TestStand with the error dialog you are seeing up? We likely will want to have a better understanding of the state TestStand is in, to proceed.
‎09-21-2020 01:18 AM - edited ‎09-21-2020 01:23 AM
Hi Kristi, Hi Dane !
The issue is solved thanks to a Staff TSE from Paris named Karim El Oueldrihi !
You can find in attachment 2 screenshots of the issue :
Basically, the solution was pretty easy for me : Karim told me that an internal KB suggested to try to fix the software (via the "National Instruments Software" of the Windows Control Panel, https://www.ni.com/fr-fr/support/documentation/supplemental/18/uninstall-or-repair-national-instrume...).
I selected only TestStand 2019 (32-bit), waited 15min for the repair, restarted the PC and voilà !
I asked Karim to modify the public KB related to this issue, which is useless at the present time :
Well, the problem is solved, I can continue to develop. Thanks !
