TestStand API - Add PassFailTest
I need to add the PassFailTest on a test sequence. I'm able to add INPUT parameters, but not the OUTPUT. They appears disabled too. How can I do?
(2,122 Views)
Hi fabio.int
I do not understand what you mean by disabled, are you able to elaborate?
See below where output parameters are processed in the same way as input parameters.  Immediately before the FOR Loop, Parameter Data In (input params) and Return Data (output params) are combined into a single array and all processed together.
Regards
Steve
(2,101 Views)
I found that if you try to set the property "useDefaultValue" for the output parameters, you are not able to write when you open the seq file on teststand.
I hope it is clear.
So the solution is: do not set the property "useDefaultValue" when you are arrenge the output parameters.
(2,090 Views)
Nice one, good stuff
(2,087 Views)
