NI TestStand
Delete FileGlobal variable from all the sequence files opened
I wish to delete a FileGlobal variable through TestStand from all the sequences which are opened or from all the sequence files which are present under project or workspace. I don't want to open each file and then delete that variable from there. Do we have anyway of deleting that FileGlobal variable from all sequence files on few clicks.
Message 1 of 9
(3,597 Views)
Hi rtingase,
If you mean from the Variables window (FileGlobals), so you can choose the first variable and pressing the Shift button to choose the last one, then press/choose to delete. With this action, the whole Global variables will be deleted from all sequences.
Best Regards,
Edgar Umrikyan.
Message 2 of 9
(3,546 Views)
I don't want to delete all the FileGlobal variables.
I want to delete single FileGlobal variable (eg- FileGlobals.EngineHours) from multiple sequences which are opened in TestStand.
Message 3 of 9
(3,542 Views)
You need to perform it manually for every sequence.
Message 4 of 9
(3,498 Views)
Here is a sequence file that shows how to create a fileglobal on the fly (in this case a boolean), as well as delete it.
create "test" fileglobal:
Locals.TemporaryObjectReference = RunState.Engine.NewPropertyObject(PropValType_Boolean,False,"",0), //Create new property Object
Locals.TemporaryObjectReference.AsPropertyObject.Name = "test",
FileGlobals.InsertSubProperty("",0,0,Locals.TemporaryObjectReference) // Insert property into station globals
delete "test" fileglobal
FileGlobals.DeleteSubProperty("test",PropOption_DeleteIfExists)
Hope this helps...
Message 5 of 9
(3,453 Views)
If I use this way, then I need to go in each sequence file and run these steps to delete variable. If I have 100 files with variable, then repetition of these steps will be time consuming.
Anyways, Thanks for your reply!
Message 6 of 9
(3,445 Views)
Use this VI over each SequenceFile with appropriate FileGlobal value (without the FileGlobals. prefix)
Santhosh
Soliton Technologies
Message 7 of 9
(3,419 Views)
I could not open this VI because I am using LabVIEW 2017.
I think this VI is made in newer version.
Message 8 of 9
(3,402 Views)
Hey rtingase,
Please find the VI in attachment, I saved it based for LabView 2017.
Message 9 of 9
(3,324 Views)
